Ir para o conteúdo principal
An Amazon tablet released in 2014 featuring a 7 inch HD color touchscreen display.
33 Perguntas Visualizar todos
Why can't I connect my device to the internet?
My device can't access the Kindle Store.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Student question
por
Adicionar um comentário
1 resposta
Solução escolhida
  • Try to restart the device by holding down the power button for 40 seconds until the device turns off, then turn it back on. Also make sure Wireless Connectivity is turned on in Settings.
  • If this doesn't work your tablet may be running outdated system software. Instructions on how to update the Fire HD 7 (4th Generation) can be found here.
  • If you are still having issues the problem may be with your actual WiFi. In this case check the internet connection of another device, if that device can't connect either try turning your router off and back on again.
  • Additional help on this issue can be found here.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jason Mellinger será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 147
