Why does my drone flip on take off
I've replaced all my props and it still flips when i press the take off button
Esta é uma boa pergunta?
Did you take off your props ,like most drones they have clockwise rotation props and counter clockwise rotation props ,if you have replaced them and have either cw or CCW on one side the quad will either not lift or flip over ,watch what side it flips too ,switch one prop at time untill you get it right .When you do mark them and the arm or motor housing with a mark as the back of the props are usually mark a b or c d hope this help
Esta resposta foi útil?
after looking only had one prop
wrong after looking some have hole's
and others dont thats how i got it wrong thanks .
thank you Cory! You hit the problem right on the head. It's flying great
you have the blade’s on wrong done the same with my Bee bop
perhaps one of the propellers is harder than the other, it would make him turn. or the size of a propeller this more than another, you will have to buy other helices engines
Make sure the correct propellers are in the correct places, colored to colored and black to black. Next, make sure you go to calibrate the drone in the flight software. Next, trim the drone, it is similar to drone calibration. If it still flips on take off, make sure propellers are tight with the tool provided, outside of that contact Parrott as it might be a software issue.
There is a video with some things to check if your drone flips during take off
did you replace motors, rear motor wires cross over to the opposite side
The plug ports and wire ends are color coordinatied still f flips at takeoff
I have a pocket drone topacc S66..it flew perfect…now suddenly with take off it tips forward…I must admit it took a fall a while ago…changed the props….
flip wilson (++] learning more daily….
thanks all you experienced flight bats
changing prop order and reviewing wire cross over .
my answer is do not make the same mistake once. difficult but yet will insist on learning for ourselves. dump that crap save peoples lives limbs etc….
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 23
Duração total: 13,844
