Ir para o conteúdo principal
Tablet Insignia com tela de 10,1 polegadas e sistema operacional Android 5.0. Identificado pelo número do modelo NS-P16AT10.
Why won't my tablet turn on?
Why won't my tablet turn on even when it's plugged in. Can you please help?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Solução escolhida
First, ensure your charging cable and outlet are functioning properly. If one of these are not functioning, your tablet may just be dead and not able to charge due to a broken charging cable or outlet. If this does not restore power to your tablet, the battery is more than likely damaged and will need to be replaced in order to restore the tablet's functionality. Check out the troubleshooting page for the the Insignia Flex 10.1 NS-P16AT10 for more information about your tablet.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
My tablet did the same thing. The thing that worked was me taking the tablet to the kitchen and throwing it away. Than I bought a Samsung tablet like I was should have done in the first place. No problem ever since. Hope this helps.
Pontuação 1
Mine just will charge 100% and it will let me go to the lock screen and the it will go to a black screen and blink the name in white for about 20 seconds then it will go back to the lock screen and it will do this over and over
Pontuação 0
1 comentário:
My screen goes from black to a lighter shade of black and nothing appears and it will not reboot.
por
Adicionar a sua resposta
Jared Pool será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 6,239
