Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
The Zenbre Z3 is a high quality bluetooth speaker that allows you to play music on the go, and will immediately amplify your device.
7 Perguntas Visualizar todos
cannot turn off /frozen!
HELP my bluetooth speakers have frozen and will not turn off,even when holding on/off switch down !
thanks in ad vance
Respondido! View the answer Também tenho esse problema
Esta pergunta é pertinente?
Pontuação 2
Comentários:
You can try this, it worked for me. I just let me battery run all the way down. Recharge and that has seemingly fixed the problem.
por
Does anyone know how to reset a Gooodmans waterproof speak mine won’t turn off
por
Please I really need your help.... Was playing my UE roll 2 speaker ,its went off immediately I plucked the charger.. For the past 1week its not turning on or charging
por
The last time something like this occurred... Its started charging and turned on after a month or more than without any repair... Thanks in advance
por
My BS-218 was playing very nicely when it said my battery was getting low. I charged it and was attempting to play it again. When I powered it up, it said in slow motion, Bluetooth mode. Thats all I can get is slow motion response. Pls help.
por
Adicionar um comentário
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
2 respostas
Solução escolhida
The reset is inside the audio jack at the back. Took like an hour to put that together lol. Dont take it appart just push button and done.
Esta resposta foi útil?
Pontuação 2
Comentários:
Hi, your advice on the position of the reset switch at the bottom of the earphone jack socket was a master stroke, as it’s a bit longer than an Apple key, I used a paper clip, felt it click and switched the speaker off, switched the speaker on normally all works fine. Thank you.
por
@alanlroberts yours was the very best! and it worked. The worst of it was the speaker is my dads and he has warned i should stop tampering with his stuff. Imagine my worry when his speaker froze.
Thank you very much. And guys in @alanlroberts advice,if you don't have a paper clip,you can use two pair of sewing needles
por
So helpful. I was push all the small holes on the top of the speaker but nothinh happen. No one tell details like yours. Never imagine the hole reset is on the audio jack. I was reading somewhere it can be the hole of mic indicator etc. So many holes but even in the manual they do not mention exactly the reset button itself. Thanks to you.
por
wooohoooo i fixed my speaker by the reset button thats located in the bottom of the aux port thanks to the above comments i now have my speaker back after days of confusion .
thanks
por
It happened to me yesterday. My bluetooth speaker was frozen. So I let it for 10 hours until all its battery go down and then it turned off. After that I turn it on.
Pontuação 0
Adicionar a sua resposta
Alan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 35
Últimos 7 dias: 231
Últimos 30 dias: 923
Duração total: 45,454
