Hi Steve. There are two thermostats clamped to the top of the boiler. In normal (coffee) mode the coffee thermostat opens once the machine reaches the proper temperature, this illuminates the ready light and cuts power to the heating element. As the machine cools the thermostat "closes" again, turning off the light and restoring power to the heating element. If the steam button is pressed this bypasses the coffee thermostat and instead uses the steam thermostat to control heating and the ready light. It's clear from the described symptoms that your coffee thermostat has failed in the "open" position, and you can verify this by checking it's continuity with a voltmeter. This guide will walk you through that; the coffee thermostat should be the one closer to the front of the machine, and if it's "open" with the machine cool then it has failed and needs to be replaced:
Testing the Starbucks Barista Heating Element
The part number for the coffee thermostat is 189422000 and it can be purchased here:
https://philips.encompass.com/item/97042...
Best of luck with the repair!
4 comentários
Yes, the boiler is heating up. I can still make a very good drink. I have to use the steam button, let it get nice & hot, then turn the steam button off, then I can get a good pour. It also steams milk very well. I took the machine apart earlier this year, and cleaned everything including the boiler - which was very clean after a chemical descale.
This is an electronic problem. Whatever device that controls the brew head temperature is what is not working.
por STEVE GARRIS
Sounds like you rmainswitch work and your steam switch. How about the coffee switch? Have you checked the wiring and components with a multimeter to see what's going on?
por oldturkey03
Unfortunately I don't know how to check it.
por STEVE GARRIS
Just thought I would post here now that this is resolved. It was in fact the 95C brew head thermostat. I purchased both thermostats for about $8 each from the link above - thanks Henry H!
A word of caution - The thermostats were located opposite of where they're shown on the parts drawing.
https://www.espressocare.com/schematics/...
After careful examination of the removed parts I was able to figure this out. Now the machine works like new!
Thank you Ifixit Barista forum!
por STEVE GARRIS
