Ir para o conteúdo principal
*#06# won't show imei
when i type *#06# won't show imei
but when i go to settings/about imei is there
i have no service
Esta é uma boa pergunta?
Pontuação 2
3 comentários:
i need a answer for this question too . i have more then 5 iphones same issue
por
do you do microsoldering
por
Pls help me with my iPhone 6 plus Didn't show IMEI number
por
Adicionar um comentário
2 respostas
Check your modem firmware. Go to settings,general and about and check if there are numbers there,if no numbers it means firmware is corrupted. First restore your phone and if still problem not solved then you go the hardware way. You'd have to change your base band chip which is a bit difficult.
Esta resposta foi útil?
Pontuação 0
1 comentário:
it's not firmware issue it's hardware
por
I think the baseband needs to be reballed, this is a common issue. During update or restore do you get error -1? If you do then it definently needs to be reballed.
Pontuação 0
Adicionar a sua resposta
Adrian Zymeri será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 3,850
