Ir para o conteúdo principal
Released in 2010, the HP Deskjet 1055 is an all-in-one printer, scanner, and copier.
7 Perguntas Visualizar todos
I changed the ink but it won't print
I changed my ink both black and tri color but my HP Deskjet1055 Printer won't print
Esta é uma boa pergunta?
Pontuação 3
2 comentários:
do you get an indication light ....error sign
por
Yes on my ipad
por
Adicionar um comentário
3 respostas
Hi Sharon, if your HP printer is still unable to print after recycling the Ink Cartridges, it's most possible due to improper alignment of it.
Try these steps:
Open HP print manager -->> Select setting and maintenance -->> Select align print cartridges
Now take out printed paper, you will see two dot lines parallel in red and black. Examine the alignment of the lines, click the numbers and letters for the best alignment, a dialogue box will appear to your screen, click continue, a new page will be print, now check whether these alignments are correctly printed on the paper, if you found irregularity over alignments, repeat this step 3 or 4 times to continue.
h/t: How to Set-up Print Cartridges to the HP Printers?
Esta resposta foi útil?
Pontuação 0
i changed the ink and now the printer isn't working right
Pontuação 0
إمبارح عملت نعم بل فعل
Pontuação 0
Adicionar a sua resposta
Sharon Laughlin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 8,371
