Ir para o conteúdo principal
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Perguntas Visualizar todos
MacBook Core Duo (2 of them) won't boot at all
So I found some old MacBook Core Duos laying around, and I thought I'd convert them into CloudReady "Chromebooks"
After installing CloudReady (without rEFIt) on one of them, and booting to Kubuntu using a special EFI software on the other one, both of them do not sound a startup chime, even though both laptops' hard drives, CD slots, and fans are running.
I tried the "place your laptop under a lot of blankets and pillows" trick, and let one run for 80 minutes, and that didn't help the cause. I can't seem to determine what's causing the issue.
On the other hand, a black MacBook Core Duo from 2006, with a Core Duo I remind you, without rEFIt, installed the software perfectly, without a single hitch. It boots into CloudReady perfectly.
I've tried many steps to troubleshoot the two, including RAM resets, hard drive resets, PRAM/SMC resets, whatever I can. I'd extremely doubt this is a logic board problem, since they just stop working after booting/installing a different OS.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
These are generally plagued by the defective nVidia 8600 GPU. There was a class action law suit on them. Doing a reflow by putting them under blankets is like putting a bandaid on a gun shot wound.
Use a hot air rework station and reflow the GPU.
https://www.consumeraffairs.com/news04/2...
Esta resposta foi útil?
Pontuação 1
2 comentários:
Don't have a hot air rework station at the moment, and for this one small project, I don't find it super valuable to get one. Any other DIY alternatives for something like this?
por
Not really. I have a stack of them I have not had time to get to yet. Not a lot of demand for these. Takes more time and effort to repair them, upgrade them than they're worth. You can get something like this for pretty cheap ($54) on eBay 853D SMD Hot Air Iron Gun Rework Soldering Station Welder
por
Pergunta mais útil
Did you try a different HD? Had similar issue solved it by replacing th Hard Drive with a new one...
Pontuação 1
1 comentário:
Haven't tried that yet, and I will once I get the chance. Seems like it could be a Hard Drive issue.
por
Adicionar a sua resposta
o355 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 233
