Will not switch to impact mode
The drill will not switch to impact when drilling
Esta é uma boa pergunta?
Steve, If your drill is indeed switchable and not just a impact driver, if the hammer mode switch feels sloppy or to easy to switch, the switch has came out of position or broken a tab inside drill. If switch seems normal but you are not getting hammer mode the wing disc and gear could be seized, worn or broke. I will post a link, not your model but should be similar to show how the hammer function works and the common components. Good luck.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 258
