How do I fix a 'Reverse Image' Top screen?
So I have a bit of a unique problem here in which the top screen suddenly started displaying in reverse. Very strange seeing as I didn't drop or damage the system in any way. One day I decided to start recording (I make Youtube videos) and I opened the system and BAM, was greeted with this...
The top screen is a lot dimmer than it is supposed to be and it looks to be somewhat flickering and has lines moving across the screen horizontally. Honestly, I can assume it's probably the ribbon cable caught or nicked in the hinge that is causing the problem, in which case I may need to just replace the top screen. However I just wanted to ask first of all to make sure there isn't an easier solution.
Esta é uma boa pergunta?
