Ir para o conteúdo principal
water damage, no sound, very slow, fan keep spinning in high speed
MacBook Air 13" Mid 2012
Spilled some water on it, then some keys stopped working, so I replaced the keyboard, the new keyboard works fine, however after the replacement; there is no sound at all (not even the boot up chime) , and it becomes very slow , even just moving the mouse lags; and the fan is always spinning at high speed;
The WIFI also malfunctioned after replacement for some time (no hardware installed), but somehow it is working again.
I tried to reset SMC, doesn't work, the LED on the magnet connector doesn't even light up.
which part might be wrong in such case? logic board or I/O board?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
Personally I would run both the board and the I/O board through my ultrasonic cleaner. There's probably still gunk/corrosion causing these issues.
If the board or I/O board have been damaged, an ultrasonic cleaning won't help, but the first step is to remove the gunk and verify that's not the problem.
Esta resposta foi útil?
Pontuação 1
4 comentários:
John, very long time, no see ;-)
por
Thanks for your answer, however I don't have a ultrasonic cleaner, and from the visual inspect, the boards do not seem to be dirty
por
Hi @mayer ! Good to see you and hope you're doing well!
por
Concerning the board, have you inspected the other side? If the liquid came through the keyboard, corrosion could easily be on the other side. Even then, it's not necessarily visible -- part of the benefit of an ultrasonic cleaner is that they clean UNDER the chips.
por
Adicionar a sua resposta
Jun Hu será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 164
