Ir para o conteúdo principal
O Galaxy S 4G da Samsung é um smartphone operado com Android 2.2 que possui tela tátil AMOLED de 4 polegadas e processador de 1 GHz.
20 Perguntas Visualizar todos
All pictures & all screens look like a negative picture
All screens are in a negative picture look how can I fix it
Esta é uma boa pergunta?
Pontuação 28
12 comentários
Everything on this phone look like negatives . Please help
por
Everything on my phone look like negatives. Please Help
por
Yes.. everything on my phone looks like negatives.. help me please
por
My photos are all looking like negatives please help me to get my photos up and running.
por
How can I put my pictures that look like negative
por
Exibir mais 7 comentários
Adicionar um comentário
5 respostas
Solução escolhida
apps-settings-accessibility-negative colors.
Esta resposta foi útil?
Pontuação 9
3 comentários:
i did not find this topic. saw visibility enhancement with color but no negative color dialogue
por
would someone answer me?
por
apps-settings-accessibility-display & text size-turn off smart invert
por
I was able to return my mobile phone to normal using the solution above but found a different dialog than negative.
You need to go to your settings and find Accessibility. This is the area where you can make changes to help those with vision, hearing, access, difficulties. On my particular phone, the I had to turn off "Color Inversion". Here is the pathway.
Settings - Accessibility features - Accessibility - Visual - Colour inversion
Your pathway may be a little different just try and find a similar path under Accessibility. Good Luck!
Pontuação 8
3 comentários:
I find this very helpful and in my Samsung A14, I had the following path Settings - Accessibility - Visibility enhancements - Colour inversion. Turn the colour inversion button off, then you will get back to normal
por
It worked perfectly in my Samsung A14 immediately in fixing all my images looking like negatives. Thank you so VERY much!!!!
por
My color inversion is off ,but still my phone shows negative display in blue color and also it's a sumsung A03 model
por
Yes my color on picture are just blurting and dard faces
Pontuação 0
2 comentários:
See below, Hope this helps.
por
could not find anything that resembled anything like your suggesting. Nothing works. truly frustrating.
por
how do i get my picture to look like pictures and not negatives
Pontuação 0
How to put my pictures back. They are all on negative
Pontuação 0
1 comentário:
Some of my photos are just negative. What do I do?
por
Adicionar a sua resposta
gmanom será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 32
Últimos 30 dias: 88
Duração total: 16,982
