Ir para o conteúdo principal
HP Photosmart printer introduced in 2010. This printer is considered ePrint capable. Has a card reader that supports Memory Stick Pro Duo, Memory Stick Pro-HG Duo, MultiMediaCard (MMC), MMC Plus, Secure MultiMedia Card, Secure Digital (SD), SDHC. An adapter is required for MMC Mobile, Secure Digital Mini, and MicroSD cards. This printer uses a 4 color semi permanent printhead.
10 Perguntas Visualizar todos
Leaking ink out of bottom right corner. Ink pooled on the inside.
I have removed the ink cartridges and there is a pool of black ink inside the printer. What is the best way to clean the inside of the printer?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
The ink in question is coming from the waste ink pads in the printer. You can see a partial look at them here, from a printer I tore down for motors that failed:
You can attempt to clean them, but I do not recommend it unless you have no other option due to the mess involved. When these are this full, it's going to be a nightmare. In addition, this is just another inkjet: you have to completely tear the printer down, including print mach removal. The cost of parts (if you can get it, otherwise you need to clean your old pads) which will take hours to complete. Inkjets are disposable, sadly. You're usually better off recycling it and buying another one.
In addition to the mess, the other concern is inkjets often have other issues that crop up later where it isn't worth fixing, often shortly after the original hours+ repair. As sad as it is, inkjets are a disposable affair.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Helpful advice re unused ink pads
por
Adicionar a sua resposta
Jeni Iannuzzi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 37
Duração total: 2,052
