Ir para o conteúdo principal
The Airport Time Capsule is a wireless router and network-attached storage (NAS) device manufactured by Apple. Model A1409 is the fourth generation revision of the Time Capsule released in June 2011.
24 Perguntas Visualizar todos
No Response and unable to reset
Hi
My Time Capsule currently not working probably, the light turn to yellow, no wifi signal, unable to connect the AirPort drive and unable to reboot or reset.
This happened the second time this year, the problem found last time I bought to repair but extremely expensive. And the same problem came with out again, does anyone got idea how to fix it (at least I want all my files back)
Many Thanks
Christopher
Esta é uma boa pergunta?
Pontuação 0
1 comentário
What was done to repair?
por
Adicionar um comentário
1 resposta
Solução escolhida
If you just want your data you can open the time capsule. It´s a normal sata drive. Plug it HDD in a new caddy and restore the data.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Christopher Ma será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 584
