Ir para o conteúdo principal
A Kenmore residential washing machine made between 2001 and 2009. Identify the age of your Kenmore washer with its serial number.
73 Perguntas Visualizar todos
Will not drain or spin makes a buzzing sound
How do I fix this problem if I bypassed the lid switch and it still does nothing what is the problem
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Dwayne Ramon what is the proper model number of your wahser and where do you hear the buzzing? It will not spin if it does not drain. Problem could be your pump, your filter. kinked hoses and other things like the lid switch.
por
Kenmore 800
Buzzes but don't drain or wash lower buzzing
por
@Ron Haas
What is the model number of the washer?
por
Adicionar um comentário
1 resposta
Solução escolhida
Dwayne, Kenmore 400 washer will not drain or spin makes a buzzing sound.
Possibly the water pump is seized/clogged/plugged, remove water pump and check pump for debri and remove blockage. Good luck
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Dwayne Ramon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 23
Duração total: 8,532
