Why my front camera not working
Why my camera not working
Esta é uma boa pergunta?
Hi
This could be due to a loose connection on the board. Your best bet will be to take the screen assembly off and double check that the connection is seated properly.
Thanks
Esta resposta foi útil?
If Chris' solution won't work you will need to replace the front flex assembly. If this is not fixing the problem it is behind that, beginning with the connector on the logicboard. Something like big pieces of dust will already reduce proper connection.
Is the brightness sensor or the approximation sensor working?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 80
