Ir para o conteúdo principal
The Dell Inspiron 15 (N5050) is a mid-sized laptop manufactured by Dell, Inc. that operates on Windows 7. The laptop features include a WLED HD display screen and a max supported memory of 8 GB.
34 Perguntas Visualizar todos
Laptop won't turn on unless charger is plugged in
My laptop recently stopped working without the power adapter plugged in. Now, it only turns on if the battery is charging. What can I do to fix this?
Esta pergunta é pertinente?
Pontuação 0
4 comentários
My dell laptop only starts and runs when attached to charger. I thought it was probably the battery so I replaced it with a new one but still have the same problem
por
so i have a Asus touch screen laptop it wont turn on only if i connect it to the charger
por
my dell only turns on when it is plugged in (it is refurbished)
por
You need a new battery. A very common issue with Dell and other laptops.
por
Adicionar um comentário
5 respostas
Solução escolhida
Your battery may be dying, or your battery might not be receiving power properly from your power adapter. You might need to consider replacing your battery if the problem continues. You can replace your battery using the following guide: Dell Inspiron N5050 Battery Replacement
Esta resposta foi útil?
Pontuação 3
I would replace the battery myself.
There is probably a battery test available in the bios when it first boots which should give some indication of the health of the battery.
Pontuação 0
Try replacing the battery.
Pontuação 0
3 comentários:
Oh hey your back! nice to see you!
por
What do you mean 'You're back'? I'm always on. My activity on here depends if I have notifications or not.
por
(Not really on here much anymore though)
por
You may have a fault with your laptop battery. To fix this you could replace your laptop battery with the same model as your laptop.
Pontuação 0
1 dos comentários:
tried everything did not so im getting a new one instead im still on this on with problems right now like now now on the charger welp
por
I have the same problem. I replaced the battery. Bought new one but still can't operate without power source plugged in. Battery shows charging.
Pontuação 0
Adicionar a sua resposta
Danielle Montemayor será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 34
Duração total: 20,801
