How do I clean my fan properly?
I think my fan has dust in it; how do I get the dust out?
Esta é uma boa pergunta?
Julia, While computer apart do not just clean the fan, clean every thing you can using a can of compressed air, this will ensure proper cleaning and reduce damaging heat build up on internal components. I will post links that will help you see how to disassemble laptop and instructions on cleaning. Check the attached links,instruction and guides, Good luck.
http://www.howtogeek.com/194479/how-to-c...
Esta resposta foi útil?
You must first remove the fan cover. After that, use a can of compressed air and blow directly into the fan. Blowing into the fan via mouth will not remove the dust.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,872
