Repair guides and support for LED, LCD, HD and other Vizio TVs.
504 Perguntas Ver todas
TV screeches and turns off
My TV just started screeching then kicked off. It will stay on for 5-10 minutes, making a high pitched sound and shut off. It is model number E601l-A3
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 2
Comentários:
@mooney7 what model is your TV? What have you checked?
por
1080p full hd
por
@asumareh18 What does that mean? You will have to provide a proper make and model number and let us know what the problem is. 1080p full hd does not mean much at all.
por
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
3 Soluções
Solução escolhida
Debbie, According to the forum below, the power supply board contains the high voltage inverters, the biggest load on the power supply and will be the faulty power supply board that's causing the screeching and shutting down. There was also a recall on your model a few years ago. Check the attached links,instruction and guides, Good luck
http://www.justanswer.com/tv-repair/8owl...
http://hdguru.com/vizio-issues-a-recall-...
Esta resposta foi útil?
Pontuação 2
Resposta Mais Útil
My Vizio E601i-A3 suffered the exact same problem "Loud noise, then TV shuts down" but replacing the power board did not fixed it. Replacing the Main Board solved my problem. I found this note after on shopjimmy.com which actually discussed my symptoms.
http://www.shopjimmy.com/vizio/e601i-a3
Vizio Y8385864S (01-60CAP001-00) Main Board (SEE NOTE!)
This part is compatible with all versions of E601i-A3 and E601i-A3E
This board may or may not have connectors at location CN13 and CN24. 01-60CAP001-00 and 864 is found on sticker.
IMPORTANT: If your TV has No Picture/No Video, this is likely caused by a bad T-con board, and NOT a bad main board.
Symptoms commonly caused by a bad main board in this model include
-No sound
-Loud noise, then TV shuts down
-HDMI inputs non-functional
-TV will not tune channels
-No internet connection
-Internet apps open and TV locks up
Pontuação 5
Just had the same issue. After a while the TV would shut off and I'd get a high pitch squeal or a static noise. I replaced the power board first and that did not correct the issue. Replaced the main board and that fixed it. So if you TV is experiencing the same you may want to start with the main board.
Pontuação 2
Comentários:
Have older RCA that does this, it is fire hazard, will dispose of tv.
por
Adicionar a sua resposta
Debbie Mooneyham será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 146
Últimos 30 dias: 654
Todo: 19,801
