Will my Verizon (CDMA) iPhone 6 work in GSM-only countries?
Does CDMA work with GSM towers?
Esta é uma boa pergunta?
Verizon is factory unlocked for GSM carriers. You should be able to use it with a GSM SIM outside the States.
Esta resposta foi útil?
It will if the phone is network unlocked.
Better check up with Verizon and get them to network unlock it for you.
Question 1 ) Yes. it will work. also you can check whether your iPhone 6 is carrier unlocked or not, contact Verizon and verify before roaming.
Question 2) Different technologies, BTS/Node B depends on the network operator. :-)
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 216
