Ir para o conteúdo principal
Repair guides and support for cars, trucks, and SUVs manufactured by GMC.
290 Perguntas Visualizar todos
How replace a cabin air filter
I have a 2012 GMC Sierra 1500 I am trying to replace the cabin air filter , looked behind the glove compartment , under the dashboard nothing.
I have been to OReilly's and LubNgo , they were not able to help me. I check on the Internet , I have been to different websites nothing. I went to mygmc.com nothing, I cant believe that one
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
1 resposta
Solução escolhida
@rolivas your truck does not have a cabin air filter. GM stopped using them some time ago. They used to be under the dash but have been discontinued in the mid 2000's.
Esta resposta foi útil?
Pontuação 3
4 comentários:
Thank you it's hard to believe cuz there's a funky smell sometime all the time , and when I went to OReilly Auto parts store they have a replacement part. GO FIGURE. Thanks again
por
I have a 2013 gmc. I had the same problem, not where it’s supposed to be. So I called my dealership and it turns out I do have a cabin filter. It is under the dash. But on mine you have to drop the lower half of a black plastic casing. So for $59.00, I just let the dealership do it. That was labor and filter.
por
My 2012 GMC does not have an air filter in the cabin. There is a blank under the dash but it is not cut out. I did find on YouTube if you want to add one there is a kit to do so and it comes with a filter cover and screw. To install it you will need to cut out the blank install the filter and cover and screw it in place.
por
@mactac101 John Wood, I too have a 2012 GMC. Where did you find the kit please?
por
Adicionar a sua resposta
rjr3598 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 46
Últimos 30 dias: 179
Duração total: 18,733
