Itunes error 4013 after screen and battery change
i've changed a screen and battery on an Iphone 5S, after that it goes directly to "Connect to itunes" on startup screen. I Connect it, get the "update or restore" question and Choose restore, but it wont go on. I've put phone in DFU and get a phone is in recoverymode, start the recovery and it starts the "getting data", then the prepeare phone for update. Screen turns of, apple logo comes on and the the screen turns red or blue (changes from one to the Other if i try several times) and turns of and error 4013 shows up. I've turned antivirus of, firewall of, reinstalled Itunes on computer, checked computer for updates. But it just Returns error 4013.
Any thoughts ? suggestions ??
I've tried With 4 different batterys and 2 different screens, no change.
Esta é uma boa pergunta?
6 comentários
Did you try it without the front camera cable plugged in?
How was the battery removed, was it pryed from the left side of the battery only and not the top or right or bottom side of the battery?
por Ben
Think i've tried With it and without it, but not 100% if i've tried without.
por thomas
Tested With Other screens now, With and without front camera and still the same. It starts to "restore" and the screen turns red og blue and reboots
por thomas
battery was removed With heating up backside, then prying from left side.
por thomas
I have similar problem, just want to add few things i have tried:
1) Took out Screen and connect to itunes - can perform Restore & Update successfully
2) Took out battery and left for a while - Open connection, phone can be used but will have similar problem after restart
por azad affif ishak
Exibir mais 1 comentário
