I can't get the Mac to power up. Sleep light is on.
Mac book pro is about 3 years old. Two days ago it wouldn't power up. It turns off, but only powers into sleep mode. The light on the front was solid on. I went the internet looking for help. Apple + V while pushing start button worked! Great - saved from depression. Today the same problem, but apple+V didn't work. Tried Mayer's suggestion - apple + alt + p + r while restarting. Nothing. Help anyone!!!
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 2
Comentários:
+ for doing research and trying previously mentioned Answers before posting!
por
I also took the battery out, disconnected from power, then pushed start. That didn't help. I can only power off, or power into sleep mode. That's why I can't run any applications - I have only a blank screen. I am borrowing a disk to try and boot from disk. I'll let you know if anything works. Perry in Russia
por
When you say you got nothing, does that mean it didn't tone or didn't fix the problem?
por
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
4 Soluções
Solução escolhida
Maybe a good solution, but I needed my computer, so I succumbed and took it to the professionals. They said I need a new video chip, about a $400 fix. I don't have the computer back yet, but I hope that ends my problems. Thanks for trying to help.
Esta resposta foi útil?
Pontuação 1
Resposta Mais Útil
Safe(shift) boot
if that works run Applications->Utilities->Disk Utility->DFA (disk first aid):Repair permissions followed by verify disk. or boot from your install CD/DVD and run the same tools.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N.
Pontuação 2
Comentários:
+ Good answer.
por
I inserted my start up disk and then tried to start from disk. Nothing happened and I couldn't retrieve my disk either.
por
Hi there, if none of the suggestions that you've received already don't work then it sounds like the logic board is in a suspended state for some reason. The only thing that I can think of is to disconnect ALL power sources (including the onboard battery) and wait for an hour or so. Before you reconnect any power source disconnect the hard drive and use an external firewire hard drive with your installation disk. Hope this gets you some results.
Pontuação 1
Hey there!
I had the same problem and hitting caps lock helped me to start up
I had the same problem two weeks ago, when changing the ram slots helped.
Now i am afraid to turn the computer off...does anyone know what i can do to make sure it starts again?
greetz
Pontuação 0
Adicionar a sua resposta
Perry será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 2,234
