Wifi siginal iPhone 5c
I just had some repair done to the board and when I got the phone back the wifi only works when I am within 3 feet of my wireless router. I was wondering if you think maybe the antenna has loose connection or something?
Esta é uma boa pergunta?
Probably wifi antenna capable not plugged in. If I'm correct it plugs under the board at the to left like the other iPhone 5 and higher.
por Ben
I'm going off memory, but I also believe there is a small piece that goes up there as well. Its a little clip looking doohicky that is easy to misplace or not align correctly.
por Josh W
It sounds like your wifi antenna maybe loose . I would return it to whoever worked on it.
por Deleted
