Ir para o conteúdo principal
Hard disk doesn't show up and doesn't spin
Hi everyone,
I had my 1Tb harddisk working perfectly except when i unplugged accidently. But it used to be fine and was working.
Last time i was using 2.0 Targus USB hub with the power of 5.0V 2.6Amp and connected my harddisk to the hub. That was the moment I couldn't get my disk in mac. I thought it was taking the time to pop up but now I knew that it doesn't spin at all.
Need suggestion plz.
Update (09/18/2016)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try different cables. Did you try it directly on a computer, better a different one? May be hub is defective. In the worst case, disassemble and carefully transfer the HDD to a different enclosure and try powering it on.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sujan Bhusal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 76
