Ir para o conteúdo principal
Repair guides and support for tablets manufactured by Azend/Envizen.
64 Perguntas Visualizar todos
How to factory reset this tablet
how do i factory reset this pc tablet Envizen digital emdoor digital
Esta é uma boa pergunta?
Pontuação 7
4 comentários:
i tried all those short cuts to factory reset it but none wont work
por
@kalan what is going on with your tablet? what does it do? Do you get to any menu? Stuck at the Android logo? Give us a bit more information.
por
Mine is stuck won't reset I forgot pattern unlock code can't reset to factory any help appreciate it
por
mine was given to me as a gift and the person forgot the password they set
por
Adicionar um comentário
2 respostas
I would try holding power + volume down, if it doesn't work try holding power + volume up, if it doesn't work try power + volume down + volume up
Esta resposta foi útil?
Pontuação 0
2 comentários:
The power and volumen up worked but when it gets to the pi, ture of the Android iy Just stops
por
I also had the same issue, purple tablet with dvd player, +and power up gives the option to do factory reset, it goes to a logo and sits there for a long time, and boots back up after several minutes with no change. still requests pin code and doesn't appear to have reset, tried twice, can not find any info on this company or any other solutions anywhere.. so much for customer support.
por
Can not swipe the screen. it is frozen
Pontuação 0
1 comentário:
try factory reseting it or maybe take out the battery. If that dose not work take it to the place you bought it and ether ask for a refund or replacement
por
Adicionar a sua resposta
kareemspooner637 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 2,465
