Ir para o conteúdo principal
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
139 Perguntas Visualizar todos
still not starting gas is new
Gas getting to carburetor but still not starting gas is new and plugs and oil
Update (09/11/2016)
Murray select riding mower
Update (09/11/2016)
Dry Murray select model 42A707-2653-E1 yes I have spark and turns over put gas in carburetor it starts and dies out
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Scott Irwin "put gas in carburetor it starts and dies out" sounds like a stuck needle valve or bad fuel solenoid. Take the carb off, clean it and check the float level and needle valve. Here is the parts manual for your engine Briggs & Stratton 42707. I also attached the service manual for the carburetion of your engine B&S Carburetion Carburetor overhaul kits are available at places like this and many others.
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
Scott, trouble shooting small engine no start links below. Check the attached links,instruction and guides, Good luck
https://www.briggsandstratton.com/na/en_...
http://homeguides.sfgate.com/riding-lawn...
http://www.mtdparts.com/equipment/mtdpar...
Pontuação 2
Adicionar a sua resposta
Scott Irwin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 240
