Fuel pump won't turn on 2012 sportster1200
I've chased every wire from the handlebars to the Ecm found nothing,I've have replaced fuel pump,coil and system relay,starter relay ,i harve power at the relay ,blue wire 12volts,wh/black stripe wire 12 volts when I hit the switch ,green/tan stripe which goes to the Ecm has power the y/r wire witch powers the fuel pump and coil no power trace that wire witch goes in to another harness with mutipale wires Ibelieve that goes to the TSM .Any suggestions will be greatly appreciated thank you
Esta é uma boa pergunta?
