I have error code 32
I have error code 32. My tv will not even turn on just the indicator light flashing yellow for the lamp.
Esta é uma boa pergunta?
Hello, hizeada. Error code 32 corresponds with an open lamp cover. If your lamp cover is in fact closed, then chances are the lamp cover is either not installed properly or the lamp door switch simply isn't working. You can try to troubleshoot this by removing both the lamp cover and the entire rear cover. First, check the operation of the switch. You want to ensure that the long lever part of the switch is not broken and is in the correct position to make contact with the lamp cover when everything is reassembled. If the switch seems to be in good condition, go ahead and reinstall the rear cover and lamp cover and check to see if you are still getting the same error.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 911
1 comentário
hizeada what model is your TV and what have you checked?
por oldturkey03
