Ir para o conteúdo principal
Released August 2003. An expensive, but high-end laptop of its time.
8 Perguntas Visualizar todos
Pergunta encerrada
not charger please help me
i have Dell Inspiron 8600 not charger please help me thank you so much your answers..........
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Need more information to help you. You don't have a charger? It's not charging? Number of Cycles on the battery?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
If you have the laptop, but not the charger; you can find replacements all over the place. One place I use (and highly recommend) for Dell parts is http://parts-people.com (http://www.parts-people.com/index.php?ac... if you want a charger for your laptop). If it is another issue; could you please post additional details?
Esta resposta foi útil?
Pontuação 1
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repai...). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,008
