Ir para o conteúdo principal
O Asus Transformer Book TX300 é um laptop/tablet híbrido.
Computer won't turn on but orange charge light lit up.
So when I plug in my computer to charge the orange charge light turns on (the computer had died so I went to charge it). I left it to charge for about 10 minutes then came back to turn it on, but nothing happened. The orange light usually flickers to tell me it's not charged enough to turn on, but it just got a little brighter when I pressed the power button and did nothing else. I tried a different charger, with the same results. How can I fix this problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Check the docking connector, it might have broken or some pins might have bent. If they are bended, try to straighten them with a needle. That might cause a shortcircuit that prevents your laptop from turning on.
Cheers
José
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Herobrinea1234 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 6,078
