Hard Drive Replacement Guide
Hi,
how can I replace the Hard Drive,
is this the same way as for the PB 1-1.5 GHz
Thanks for any help,
Lutz
Esta é uma boa pergunta?
Hi,
Lutz
if you use the guide for your powerbook g4 aluminum 12" 867mhz to remove the logic board, follow steps 1-25 and it will show you how to remove the hard drive. then just follow the steps backwards to install the new hard drive.
here is the link to the correct guide for your computer,
Esta resposta foi útil?
+ good
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 700
