Ir para o conteúdo principal
Nikon Coolpix S6300 is a small and light weight compact digital camera
7 Perguntas Visualizar todos
About picture processing time
When i take a shot the its takes more time to switch foe next shot screen.
so for this i can't able to continuous shots.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
what speed is the memory card inside ? class 4 or class 10 ? Class 4 is much slower so this might be the issue
por
Adicionar um comentário
1 resposta
On top of the Class of your card, there's also the type of card you use. Depending on what your camera is compatible with, aside from the standard SD or SDHC, there are also SDXC, CF and an ever-growing array of increasingly fast cards coming onto the market, the speeds of which are making continuous shot modes much more continuous than ever before.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Yogesh A N será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 56
