Ir para o conteúdo principal
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210 Perguntas Visualizar todos
Where can I buy an OLED display only for Apple Watch?
Where can I buy an AMOLED display only for my 42mm Apple Watch? I attempted a glass/digitizer repair and when I was removing the LED from the glass I broke the seal on the LED without realizing what I had done. Then when I used alcohol to remove the flue residue it got inside the display and ruined it. I want to buy just the LED since I already have the replacement glass and UV glue. THANKS!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
unfortunately there aren't many placed that sell just the OLED screen alone. The best suggestion would be to purchase one online that has been locked and use the screen assembly off of that. Good luck to you.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Candido, you said there an't many who sell the display alone. What are the ones you know of? I could not find any from my sources.
Thanks!
por
normally only lcd assembly, not have anyone to sell only oled display .
Pontuação 0
Adicionar a sua resposta
Brandt Johnson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 437
