Ir para o conteúdo principal
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146 Perguntas Visualizar todos
"Module not Compatible" after replacing USB Cable Ribbon
I replaced my usb ribbon , I have a LG G5 from verizon, however after I replaced the ribbon and tried to boot, it says the module is not compatible, however when I put the original one back in, it works fine. So I think I have the process down well, but for some reason it is saying not compatible and not sure why. I tried 2 different usb ribbons from ebay, both of which say they support the verizon module, so not sure what to do.
Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Don't buy part off ebay what most likely just bad cable
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Terry Horgan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 933
