Ir para o conteúdo principal
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210 Perguntas Visualizar todos
Replacement 42mm Screen doesn't fit
I purchased a replacement screen from iFixit and followed the replacement steps. Now when I am putting everything back together the screen doesn't want to fit back on. It sits flush all of the way around except fro the top. When I look at the side that is not closing properly I see two little tabs that don't appear to be on my old screen. Now I am not sure if they were at some point part of the original screen since the screen was broken and came off of the watch in pieces. Here is a picture that will hopefully help show what I am talking about.
Thanks
Chris
Update (08/23/2016)
Here is another picture. It shows the side where the clips should clip into.
Update (08/23/2016)
After resetting the watch and repairing it, it appears to work properly but I still can't get the screen to sit flush.
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Can you see any broken clips under where these tabs go?
por
its like there are no spots for the tabs to slide into
por
I'll take another picture when I get home in a couple of hours
por
Adicionar um comentário
2 respostas
Solução escolhida
As far as I know, and by looking at several pictures from ifixits guide, parts and google images, the Apple Watch LCD shouldn't have clips, as the screen is held down by double sided adhesive.
I would contact them about it to see what can be done, as their customer service is fantastic. :-)
Esta resposta foi útil?
Pontuação 1
We’re going way back here but I'm running into the same issue with parts from a different supplier. These look like apple original take offs.
Pontuação 0
Adicionar a sua resposta
Chris Martin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 279
