Ir para o conteúdo principal
Dell 19" LCD Monitor, charcoal gray in color, released in 2004.
8 Perguntas Visualizar todos
No picture says in power save mode
When I turn on my TV a blue box appears and says dmspc power save mode
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
This can have multiple solutions so heres a few:
  • The graphics port went bad, try hooking to a monitor known to work
**If the port is bad most desktops have several options for PCI slots to install a new graphics card
  • The input on the monitor is wrong , for example if you're connecting HDMI bur the monitor is on VGA
  • The power supply or other internal component could be bad
I would first try hooking it up to a 2nd monitor/TV.
Esta resposta foi útil?
Pontuação 0
try checking the computer and seeing if it iis awake or if the monitor is connected to the right port.
Pontuação 0
Adicionar a sua resposta
Kim Smith será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 201
