iPhone not turning out/ not being recognised in iTunes
Hi,
I have an iPhone 6 which I bought not turning on. The screen is cracked. I have opened it up and both water sensors are still white so doesn't look like water damage. I have changed the screen and battery but it is not switching on. It is also not being recognised in iTunes. The motherboard isn't getting hot or overheating. Any ideas?
Thanks
Esta é uma boa pergunta?
Logic board/ charging flex/ battery are the possible faulty parts.
If you can, try with other parts, if you can't, buying parts are not a wise idea.
Better to take it to a repair store.
por Freddy Krueger
Check if it is drawing any current from the usb cable with a multimeter or a specialized charge tester.
por echow2001
