Ir para o conteúdo principal
A versão somente wi-fi do Air iPad, da Apple, modelo número A1474. Disponível nas cores cinza espacial ou prata, conta com o processador A7 personalizado, com configuração de armazenamento de 16, 32, 64, e 128GB.
299 Perguntas Visualizar todos
My new digitizer's bottom half of the screen is not registering touch.
My new digitizer's bottom half of the screen is not registering touch. What is wrong? The top works fine. but if I were to input a passcode in landscape for example. I can't touch the 3,6, or 9.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Edric Chen,
it should be digitizer defective. you may have to replace the digitizer
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
If you can reseat that digitizer connector by pulling it out and putting it back in, you'd be surprised how many problems that solves. :)
It's worth noting, that if your iPad had any power at time of replacement, erratic behavior can occur. I recommend you hold both the Sleep/Wake and Home buttons for at least ten seconds, until you see the Apple logo, before considering the digitizer defective.
Pontuação 2
2 comentários:
OP: If you do intend on opening the iPad Air yourself you should have a digitizer ready just in case you crack the glass as it requires heat and a lot of patience in taking the glass off and using the right tools.
por
I have reseated it multiple times to no avail.
por
sounds like a defective digitizer, have you tried possibly a new digitizer or the old one if it didn't have any touch problems
Pontuação 1
2 comentários:
Just tried the old one. Didnt think of doing that for some reason. That one works so the new one has to be defective.
por
yeah thats what it looks like, see if you can return your defective part or exchange it for a new one, where did you buy the digitizer?
por
Adicionar a sua resposta
Edric Chen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 1,483
