Dropped in water lighter spots on screen.
My iPhone 6s fell into my dogs water dish it was in around 10 seconds. I put it in rice for the day turned on sound works everything works but there are couple lighter colored spots on the screen. Is there a way to get rid of this?
Esta é uma boa pergunta?
3 comentários
That is the liquid moisture inside the backlight of the iPhone 6s screen. Not sure if it's easily separable as the 3D touch is basically fused with the screen.
You will most likely have to put a new display on like Jamie H said.
por Ben
So a new screen would fix it. If I just left it do you think it would be ok.
por Britni Stevenson
@brit yup a new display should fix this. Just to reiterate as we have done on here many times : Rice does not do anything. If your phone get submerged you will have to clean it properly or it will potentially fail.Check on here for more info.
por oldturkey03
