Ir para o conteúdo principal
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
222 Perguntas Visualizar todos
wont stay on for more then 1 min after unpluge ?
buy axcient i stuck a pin in the head phone pluge . after that my phone dont work . it shuts off in less then a min without being connected to the charger . what can i do to fix it .
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Do the headphones work still? Or did you mean you stuck it in the charging port?
por
Adicionar um comentário
2 respostas
Solução escolhida
Sounds like you need to replace the battery, get it here.
Esta resposta foi útil?
Pontuação 0
Was the pin the first time when you noticed this? Did your battery work well beforehand? Then the pin in the "Headphone jack" shouldn't have done anything to battery life unless you somehow shorted and damaged it?
Pontuação 0
Adicionar a sua resposta
david será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 569
