Upgraded HD to SSD and added RAM system is still slow.
Hello all,
My MBP is early 2011 and I just upgrade HDD to SDD and 8GB of RAM. My system it still running slow.
It's the replacement drive. It is SSD Apacer AST680S 240GB. I also just replace RAM to 8GB.
After upgrading to SSD, it a bit faster than the original HDD but it still slow.
Esta é uma boa pergunta?
3 comentários
Can you give us some more details here. If you followed my instructions did you encounter any errors? If not then you likely need to do some house cleaning as well as defrag the HD.
Download this app: Disk Doctor it will cleanup the old cache & log files that build up over time. You'll also want to clean off at least 1/4 of the drive so the OS has some space. Make a good backup as well before going to the next step.
OK, once you've freed up space on your HD (the more space the better if you can). Get a good defrag tool like this one: Drive Genius.
That should do it. Otherwise you could have a hardware issue like a bad SATA cable or the HD its self may need replacing.
por Dan
Sadly a video won't help you here. You've given me enough clues to understand what your problem is!
por Dan
Your systems specs: MacBook Pro 13" 2.3 GHz i5 (Early 2011)
Your SSD's specs: Apacer Thunderbird AST680S SSD
por Dan
