Ir para o conteúdo principal
The Canon EOS 60D is a 18 MP DSLR (digital single-lens reflex) camera with an articulating LCD screen. The camera was released August 2010 and is identified by the EOS 60D printed on the front of the camera.
Canon EOS 60D won't switch on
Hi,
My Canon EOS 60D is about 10 months old. Can't get it to switch on - have fully charged the battery but it just flashes empty. Bought a second battery same thing.The battery door closed, tried with lens on and off, still nothing.
Any ideas?
Thanks!
Esta é uma boa pergunta?
Pontuação 5
2 comentários
i have got same problem . i consulted with the technician , he said i have to change the mainboard which cost me around 500$(too expensive) . . i also searched in youtube for repair. as in the video it used to happen due to breakage of communication of mainboard and battery due to small screw , and that screw we have to tight as per video suggestion. i still what to do ? please give me good suggestion.
por
Hi,
Can you post a link to that specific video?
por
Adicionar um comentário
5 respostas
Solução escolhida
Try this:
Turn camera off. Remove lens, battery, memory card.
Press and hold down shutter release for 30 seconds.
Insert in following order:
Insert battery; try turning on camera; if no response, turn camera switch to off again go to next step;
Insert Lens; try turning on camera;
Should be working at this point. If you now insert the card and get the same problem again, try a different card. Also try formatting the problem card.
My card wouldn't format in a PC but did successfully format with the camera.
As the Canon tech explained, this process clears the camera of any corrupted data and error messages. It is often caused by cards that are not functioning optimally.
Esta resposta foi útil?
Pontuação 15
11 comentários:
holy sh!t... thanks man this is brilliant!
kinda worried my camera is already dead after not being used for over 1 yr!
por
You're welcome. I've also found that sometimes "bad" memory cards just need the electronic contacts to be cleaned with a soft dry, lint free cloth.
por
Brilliant! I had exactly this problem, and it worked first try!
por
Seems to have done the trick. Amazing! You saved me a panic and turning into a grumpy and foul person. I use my camera a lot - it would be quite a blow to be without it. Thanks so much!
por
Thank you so much, your answer just help me to fix my camera this morning and save me from anxiety.🤗
por
Exibir mais 6 comentários
When you say "flashes empty" is that the flashes on the charger? If it's blinking slowly on multiple batteries then it isn't charging them correctly. If something is showing up on the camera screen when you switch it on, then I think you can rule out the battery door as the problem. If I recall, the camera won't do anything if the door isn't shut properly. Look and make sure the contacts for the battery inside the camera's battery slot is clean and has no corrosion issues.
Pontuação 1
1 comentário:
My Canon 60d camera mode dial always switch it self whenever am not operating it why?
por
hi i've the same problem as well ,i believe is the door sensor .if i just place the battery in it will not flash but once i close the door it start to flash and I'm still looking for and answer.
Pontuação 0
1 comentário:
It sounds like your door is working correctly. When you close the door it changes the state (no light to blinking light) which means the camera is detecting the door was closed. This moves you more towards it being another issue in the camera.
por
Hi,pull the board and test all connection points on board and body.fix any problems,it doesnt take much to break a trace.microscopes are great but a mag glass will do.look for cracks on board.Thats where i would start.
Pontuação 0
My Canon 60D often does not come on when putting back the battery. So i take a small piece of paper and wedge it between the battery and side case so that battery sits firm in its sitting area.. I have to do a few attempts to get this work. Once the battery is sat right in the battery area it works. Basically the battery does not make good contact with the connectors.
When using sometimes I have re-open battery door and just move the battery a little and it comes back on again after closing the door.
2nd Canon camera I've had that done this..
Pontuação 0
Adicionar a sua resposta
Basta será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 128
Ao todo: 19,064
