Display connection is covered in tape
The display cable is covered all around with a yellow transparent tape. It is not attached to the socket. When i peeled the tape back the cable came with it. Could this be the source of my display problem. And no this has never been tampered with. I do not understand how it worked before. Should i connect and try before i proceed with display replacement. The mac was dropped and display went out.
Esta é uma boa pergunta?
2 comentários
Can you give us your exact model info. If you don't know you can check it here using your systems S/N: EveryMac
por Dan
That machine has been worked on. Apple did not do that.
por mayer
