Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Repair and disassembly guides for Brother printers.
219 Perguntas Visualizar todos
it wont print on paper
can u help me with a problem, my brother mfc- 255 it wont print on paper.. it work properly but no ink on paper, if i look close i see dots on paper that it was trying to print but i dont know how it is not printing on paper can u help me with this problem ?
Pontuação 0
Comentários:
Maybe it was offline
Open the printers’ ‘start’ menu and click on ‘control panel’ and tap on ‘printers and faxes’ icon. This sequence of moves will open up a new window and a list of printers will appear. The list includes all the printers currently setup on the serving computer.
Double click on the icon of the printer if the user wants to reconnect online. A pop-up window will then appear, this consist of details of all current print jobs scheduled on the printer.
And last, go to ‘printer’ in the menu window and tap ‘use printer offline’ and automatically this action will reconnect the printer ‘online’ from the ‘offline’ status.
por
Adicionar um comentário
4 Respostas
Chosen Solution
Junior I'd start with cleaning the print head. This video should help. Different model same idea
Pontuação 1
Let’s try these options to fix the problem.
  • Power off your printer for one minute and power it back on.
  • Now reconnect your printer to the computer.
  • Check the ink label.
  • Cancel all print jobs and make a new print. I am sure, it will start working.
  • If it is still not working, you need to go visit: brother printer says offline and follow the instructions to fix the problem.
Pontuação 1
Hello Junior, Make sure there is paper in the tray(s), check the ink or toner cartridges aren't empty, the USB cable is plugged in or the printer is connected to Wi-Fi. And if it is a network or wireless printer, try using a USB cable instead. In our experience, some Wi-Fi printers are unreliable in terms of their connection.
Pontuação 1
Nozzle Cleaning on Printers With Touchscreens
1. Tap the touchscreen's "Ink" button or ink indicator.
2. Touch the "Cleaning" option.
3. Touch either "Black," "Color" or "All" to clean the black nozzle, a single color nozzle or all four nozzles, respectively.
4. Wait for the printer to finish cleaning the print head. When done, it returns to its Ready mode where you can either print or generate a Print Quality Check Sheet to see if the cleaning was successful. If it was not, repeat this process three more times.
Pontuação 0
Add your answer
Junior will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 155
