Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
785 Perguntas Visualizar todos
not charging after battery replacement
Just replaced my old battery with the one I purchased from you. Great and easy fix, loved your instructions. But here is the problem, even with the new battery my Ipod does not charge. Originally I had a block charger that overheated and even melted. I of course replaced it and hoped that replacing the battery would fix my problem. It works fine while it is plugged in either a block charger or my pc but it obviously does not charge my battery.The battery icon displays full while the Ipod is plugged in. Do you think it is possible that I have a "fried" logic board?
Esta pergunta é pertinente?
Pontuação 3
3 comentários
Since I did not get any answers I figured what the heck and went ahead and order a logic board. Should be no problem with the manual that is posted on here. I let you all know how it went once I receive my new logic board.
por
same thing happened to me. how it go???
por
It went great ;) replaced the logic board and the iPod is still jamming :-)
por
Adicionar um comentário
1 Resposta
Solução escolhida
Since I did not get any answers I figured what the heck and went ahead and order a logic board. Should be no problem with the manual that is posted on here. I let you all know how it went once I receive my new logic board. It did work and the error was on the logic board.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
oldturkey03 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,611
