Ir para o conteúdo principal
Released in February 2012 by Garmin. The Garmin nuvi 2555 LMT has a 5-inch dual-oriented display, Bluetooth capabilities, lane assist, 3D traffic, and Guidance 2.0 software.
7 Perguntas Visualizar todos
My GPS Reboots unexpectedly very often
My GPS always shows "lost external power" and reboots unexpectedly. But the cable works fine for my other Garmin GPS, and I reset the device to default, Still not working.
Please help, thank you!
Esta é uma boa pergunta?
Pontuação 3
2 comentários
Thanks for your reply,.
Yes, it's an original charger which works fine with my other Garmin GPS.
I think that's the problem of mini-USB too, any recommendations?
Thanks!
por
you can try to open the gps. i did it before and its not hard to do.. check the main PCB for the charging mini usb. when its loose you will have to solder a new one. check the cable's as well. cause i had a molten cable of the battery...
por
Adicionar um comentário
1 resposta
Pergunta mais útil
It is possible that the mini-usb connector on the back of the Nuvi may have failed.
Test the connector by gently wiggling it. If it feels loose, it is a an indicator that it may have become disconnected internally.
Is the red light from loading still on when shutting down and reboot?
It is a common problem to this GPS.
Is it an Original charger and cable?
Kind regards,
Kevin
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
ejilliantan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 933
