Controller battery won't charge
The battery in the controller won't accept a charge. When I plug in the charger I can turn the controller on, but it won't charge, even when left plugged in for hours. Also, when plugged in and turned on, the red light next to the four white lights is illuminated. I'm guessing the battery is bad. How do I replace the battery?
Esta é uma boa pergunta?
6 comentários
I have the exact same problem. I have only used it once!!
por Derek Scott
I'm in the same boat however, mine will flash the one led for a few moments and then will stop.
por manchesterman96
Same problem with my phantom 4 RC. Send to repair, happen again after 1 month.
por BT LOH
Just wanting to know PS, XBox, Nintendo Wii etc... and when it is plugged in, does the controller work normally when it is plugged in? Can you play if controller is plugged in?
por sirozmonster
Yes. Does this mean it is simply a bad battery?
por Charlie Gaines
Exibir mais 1 comentário
