Ir para o conteúdo principal
Phone won't charge, screen also has border around it
So I swapped out my cracked iPhone 5 with a new replacement screen, and put in a new battery because last week the phone died it wouldn"t charge at all not even show the dead battery logo when pushin the power button. So my thing is before that the phone had a charging issue, it would only charge when powered off ans posistoned a certain way but it would die extremely fast even when on %100
Now that I swapped out the battery and screen it turned on and seems fine but I have black borders around the screen while its on, but as far the charging issue goes my phone turned off when I tried to go into Snapchat which it did in the past also plus the new battery doesn't charge whiles its on
I'm assuming at this point for the charging issue that it can be the charging port..?
But for the screen I don't get the black borders around it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hello, for the screen it sounds like a defective screen or maybe you haven't attached the ribbon cables all the way tight.. as for the battery, it might be that there was a shortage somewhere. Try letting the new battery drain all the way to about 5% or less and charge completely to 100% after installing it. This has worked for me in the past. Hope that helps
Esta resposta foi útil?
Pontuação 1
The screen sounds like it may be defective, and the charging issue doesn't sound like a charging port issue just because the charging port wouldn't conflict with Snapchat
Pontuação 1
Adicionar a sua resposta
Gregoey será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 48
