Ir para o conteúdo principal
In the United States, the Tiburon was first offered in 1997 with base models using the Elantra's 1.8L 130 hp engine while the upscale FX received a 2.0L four-cylinder engine.
2 Perguntas Visualizar todos
engin light is comming on
why is my car hesitating wile driving
Esta é uma boa pergunta?
Pontuação 0
1 comentário
More information about how the car is running would be good and as @mayer suggested get the engine code read . this can help a lot when trying to diagnose the problem
por
Adicionar um comentário
2 respostas
Solução escolhida
First thing I would do is to take it to an AutoZone and get a free computer read out.
Esta resposta foi útil?
Pontuação 2
Hi, if your engine light its blinking on the dash while you are cruising and the car it's hesitating, it means that you have 1 or more misfiring cylinders. That may be for several reasons: check your sparks, sparks plugs or ignition coil.
Then if is all good check you fuel pump and filter, and be sure to have the correct pressure on the injectors and all working.
In any case it's very useful an OBD Scanner, because it could tell you exactly which cylinder is failing so you can focus in that one.
That's the easy and less expensive thing. if it's all good, it may be a head gasket or worst, timing belt or an endless list of possibilities.
Pontuação 0
Adicionar a sua resposta
kohli5162 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 340
